Help identifying this garage door?
Received 0 Votes
We purchased a foreclosure with a busted Garage Door Window. I cannot find a replacement frame ANYWHERE! I found a similar Clopay, but it won't fit. I've had garage door companies out, checked Lowes, & Home Depot, and all local stores. My only other option is to replace all 8 inserts! Any help would be greatly appreciated!!!
Welcome to the forums.
Your inserts appear to be a style known as Williamsburg. That's a pattern, not a trade name. I doubt that you will be able to come up with a single insert. You will probably have to buy a complete set.
You might consider using the insert to the right - in your picture - as a template and make a copy out of plywood. You could paint it to match. It would not be a perfect match, but from the street it may beat the blank space you now have.
That is a Clopay door. Model #FBP-08
Not sure what the 503 stands for. (possibly window style)
Clopay Imagine FlipBook
Received 0 Votes
I just realized that you said the model is FBP-08. I couldn't find that online anywhere. Is there a website that I can go to that shows it? I have been looking everywhere for all the numbers listed on the door and could never find anything.
Very strange as that model took me to Clopay but it also goes to Wayne Dalton doors.
The actual model isn't listed but when you enter your model number in their search.... it brings up the following page.
wayne-dalton/residential/classic-steel/Pages/garage-door-model-8300-8500.aspx
wayne-dalton/residential/Documents/brochures/brochure-models-8300-8500.pdf
Do you have a Menard's in your area? They handle Ideal brand doors and have that insert pattern available.
Note: They call it "sunrise".
