Shed for kayaks and lumber storage: 4x4 's or 2x4's cemented in ground
Old 07-16-16, 10:17 AM
C
Was going to build something like this, SUP Shack Finished - Stand Up Paddle / SUP - Seabreeze Forums! saw this on a paddling forum years ago and have been dreaming about it ever since.: "/> with lumber storage hanging on left and kayaks on right. I was going to cement posts in the ground (PT) thought I could save a few $$ by just sisterering 2x4's and cementing in the ground rather than 4x4's. I know 2 2x4's arent the same dimensions as 4x4, but that isn't important for this project.
Old 07-16-16, 11:25 AM
Received 757 Upvotes on 662 Posts
Most 2xs aren't rated for ground contact. I'd be concerned that 2x4s might snap. 4x4 PT shouldn't increase the cost of the job enough to be a concern.
Old 07-16-16, 11:52 AM
Received 1 Upvote on 1 Post
I definitely have to agree with marksr, you definitely need to go with 4x4s. Other than the problems mentioned by mark, the double 2x4s will be much more susceptible to twisting as a dry and you will also get water infiltration between the 2 of them causing additional rotting concerns.
Old 07-16-16, 07:46 PM
Received 125 Upvotes on 110 Posts
The way that's built would never stand up to a building inspection any place I've lived, and with your snow loads it would be asking for trouble.
Wood siding installed to close to grade so it's going to stain and rot sooner.
Again code to just bolt rafters to the side of a post like that, and under sized rafters.
Purlins are to small.
No flashing at the wall to roof.
Rafters spaced to far apart.
Not enough roofing over hangs on any of the roof in that picture.
Way under sized beams for the rafters to sit on.
