Shed floor out of square
#41
Thanks for the response marksr - I think the level is about 30".
Roof has been framed and put 4 sheets of plywood on today, so good progress. However, I noticed a bunch of the rafter tails on the front eave extend out past the sheathing by 1/2 inch. My fascia board will be 1 x 6 PVC, so my thought is the drip edge can easily span this 1/2" gap plus 3/4" fascia (total 1 1/4"). Does this sound reasonable (I pulled up one example of drip edge on HD's website, it shows the nailing edge of 2.43")? I'd rather not pull up the plywood at this point if I don't have to.
I understood the concept of trimming rafter tails but didn't quite put it into practice I guess. Thanks for any help.
#42
Sure your gutter apron can span the difference, the problem is that your fascia won't be straight if you didn't snap a chalk line on the rafter tails and trim them so that they are straight. There are plenty of tools that can trim the tails without the need to remove plywood. Or you can shim the ones that are too short rather than cut the ones that are too long.
