Building a new shed
Old 04-12-17, 12:34 PM
D
Building a new shed
Hello everyone,i am building a 16x16 foot frame shed.one wall will be the exterior wall of my garage.i installed a 2x8 ledger board on the garage wall.question is,how far apart should i place my concrete forms to support the floor joists,also using 2x8's?thanks
Old 04-12-17, 12:54 PM
D
Received 228 Upvotes on 180 Posts
What you going to put in it (weight) & what are you using for flooring (thickness, material etc)
Old 04-12-17, 12:57 PM
Received 786 Upvotes on 689 Posts
How did you attach the ledger board? How high off the ground is the floor framing? I can't say for sure but I think 16' is too far for a 2x8 to span so you'd need a beam at halfway for extra support. The carpenters should be along later with more/better advice for you.
Old 04-12-17, 02:15 PM
D
Dixie,ill be storing 3 motorcycles and other odds and ends out of my garage
Old 04-12-17, 02:20 PM
D
Mark,i used 1/2 inch concrete anchors into the slab of the garage and 10 5/16 lag bolts into the sill plate of the garage
Old 04-12-17, 04:42 PM
D
Btw,ill be doubling up the 3 outer boards effectively making the 3x11
