Clicker CLT1D garage door remote
Old 05-03-17, 07:41 PM
Raemarti's Avatar
Hello, trying to follow some of the directions and fixes on my garage door remote. I have a Clicker CLT1D, 2 button and uses a 9-volt battery. I have a pre-1990 Liftmaster Moore-O-Matic receiver still working fine. It does not have the door lasers. Here's a pic of the remote. Where is the reset button or switch on this? I am trying to do a full reset on it. I have unplugged the receiver and have re-keyed the dip switches on the remote ON and OFF and back again but can't get remote to work. Have not toggled the dip switches on the receiver only unplugged and plugged back in again. Does this remote have a reset? Thanks for all your good information here.
Name:  Remote Opener  a.jpg
Separated from... http://www.doityourself.com/forum/ga...same-time.html
Old 05-03-17, 08:14 PM
Received 1,029 Votes on 955 Posts
There isn't a reset on that remote. It's just dipswitch programmable.
Memory needs to be usually cleared from a receiver... not a transmitter.
Has that Clicker ever worked with that door opener ?
Old 05-03-17, 10:44 PM
Raemarti's Avatar
Yes, it has worked on my single garage door for several years and then just quit working. No reset? No factory reset?
Old 05-03-17, 10:59 PM
Raemarti's Avatar
I was following a thread with the last post by Starmo###(?numbers). He had several 1 thru 10 directions, I was trying to follow.
This is what I wrote myself first, and then found this other information by Starmo in a thread and reworded my post.
Hello, I have a LiftMaster Moore-O-Matic garage door opener. It was built with the home in 1986. It still works fine from the wall button. My remote opener is a 2007 Clicker CLT1D, 2 buttons and uses a 9-volt battery. Of course, changed 9-volt battery. I have re-keyed all the switches to match the receiver but can't get it to work. I've got every switch in off position and programmed the buttons by holding both down, waiting for the LED to flash and then picking my choice of button for opening. The LED flashes yellow. <<(The LED light cover is yellow.) Then I re-keyed my remote dip switches to match the switches on the receiver. Can't get the remote to work. This Clicker remote was never used much as I don't park in the garage. Always used the wall switch if needed and I have a man door off the garage to outside so little use on this remote. Do you think age has got it or maybe I am missing something. I am following the manual came with.
After posting, it said this thread was 'closed'. Then you popped-up. Thanks for the help. This remote has worked in the past but quit awhile back. Checking to see if I can bring it up again... Thanks.
Old 05-03-17, 11:03 PM
Raemarti's Avatar
I have everything in OFF position on this remote photo. Trying to bring it up if possible. Will try to clear the receiver memory. Thanks!
Old 05-04-17, 03:22 PM
Raemarti's Avatar
Red face
One question before I re-key the receiver. Would you know if the receiver dip switches have to go back to the same ON/OFF toggles as they were prior or whatever choices I key in would work? I know both have to match receiver and remote? Probably best to stay with the original toggles so I don't key what a neighbor may have. A billion chances probably could not duplicate their toggles. But just curious... want the least amount of receiver switches moved around because receiver is an old unit. Although receiver switches look fine, the plastic switches could crumbles right before my eyes from age. Thanks! You all are such good helpers here. :-)
