Garage floor/apron repair
Old 10-16-17, 11:24 AM
T
Received 1 Upvote on 1 Post
We recently had a mudjacker bring the apron back up as it had settled somewhat, presumably due to water ingress at the apron/floor joint. He strongly urged me to follow up by filling that gap, as well as the floor control joints with self-leveling polyurethane caulk to prevent future water entry, which I am doing now. I have eliminated the waterfall off the eave by redirecting roof runoff via rain gutters... that helps a lot.
For the small random cracks (1st photo) he suggested I use a thinner-bodied material; my local home improvement store has this in quart size squeeze bottles, but it is not polyurethane. Would this stuff be appropriate or would the urethane caulk be better for these as well?
What should I use to repair the large chips/spalling (1st & 2nd photos) caused by salt/freeze/thaw... some sort of mortar mix, vinyl patch, or other?
I tentatively plan to implement some sort of floor sealant in the future, so any fillers, other than what I'm using in the control joints would need to be compatible with that.
How shall I repair the broken part of the apron seen in the 3rd photo? Those broken pieces are only about 2" thick. That surprises me: I was expecting more thickness there, but then again, I'm far from an expert.
https://imgur.com/a/jHXsl
Old 10-16-17, 11:46 AM
D
Ace sells a product which is nothing more than Portland with sand. It's called Topping something. Chop out what's loose first & widen the crack. I also recommend to mix it with a bonding agent. It looks like a gallon of milk & you mix it with the dry mix.
Old 10-19-17, 08:36 AM
T
Thanks Donato, I'll put that stuff on my shopping list.
Old 10-19-17, 03:22 PM
Tolyn Ironhand's Avatar
Received 868 Upvotes on 731 Posts
Also check out non-shrink grout. It is found in the cement aisle.
Old 10-19-17, 03:41 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
For those small cracks do not use a cement based patch it will just crack again.
Clean the crack and use Sika self leveling sealer, it will provide flexibility when, not if, the crack shifts.
