Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Garages, Garage Door Openers, Work Shops & Sheds, Breezeways and Carports
Reload this Page >
Craftsman Garage door opener - not opening/closing. Also LED blinking 11 times
Old 10-22-17, 07:45 PM
I have a Craftsman Garage door opener. Today suddently it started malfunctioning wherein when i try to open it, doors lifts up little bit (say one feet) and then it stops. As part of initial troubleshooting here are my observations:
- Door stays in same place whenever i press the button. I would expect it to open on first press and close on next press. Instead it opens for one feet. Next press, it again closes and then opens upto same location
- If i disengage the door, i see the belt rotates only upto certain level and then it stops (same distance when the door was engaged)
- The obstruction sensor shows green light and i see that if i block the path between two ends, the green light goes off. That makes me thing the safety sensor seems to be working fine
- I opened the side where bulb goes and some wires are connected, and i see a LED blinking exactly 11 times and then stops for few seconds and repeats. I checked multiple times and it is 11 blnks and not 10 as comes up in google when i search for blinking related to garage door
Any suggestions?
Old 10-22-17, 09:10 PM
Received 379 Votes on 356 Posts
Welcome to the forums.
It's helpful to have a model number to go along with the problem.
That tells us the manufacturer too.
Old 10-23-17, 06:52 AM
Thank you for the feedback. It is the following model:
Craftsman 3/4 HP DC Belt Drive Garage Door Opener with DieHard Battery Back-Up
Sears Item # 00953918000P Model # 53918
Sears doesn't sell this anymore but link of product from Sears: Sears.com
