Year 2000 garage door opener remote wont work in a 2006??
Old 09-27-18, 09:23 AM
W
I have a craftsman door opener from year 2000 why cant I use remote on the chamberlin from 2006 is it different coding/frequency etc ???
I thought these 2 brands are the same manufacturer? I believe the chamberlin is myq
Old 09-27-18, 06:00 PM
Received 850 Votes on 796 Posts
There is no guessing. You'd need to post the model number from the old opener and the new one or the remote that won't work. I run into this problem constantly with peoples garage door openers. They get the wrong remotes and blame me when I can't program them. Many are year specific as frequencies change as well as coding methods.
Old 09-27-18, 09:04 PM
W
Year 2000
41A5021-3E
2011
41ACO50-1M
my mistake its 2011 not 2006
390 and 315 correct ??
Old 09-28-18, 02:27 AM
Doorman2722's Avatar
Received 16 Votes on 16 Posts
one has an orange button and one has a purple button, so they are not compatible. An 893 MAX will program to both of those openers because the remote is programmable to be backwards compatible.
Old 09-28-18, 05:04 AM
W
Thankyou good to know . And which type of remote is used with the newer one ?
AND same goes for keypads. For both and newer one?
Old 09-28-18, 02:11 PM
893 max will work with the new one as well, 877 max keyless will work with all three as well but it will only program to one at a time, the 893max you can separately program each button to three different LM systems
Old 09-28-18, 03:07 PM
W
So there's no keypad that will work for 2 different doors with 2 different freq
Old 09-29-18, 03:29 AM
not that I am aware of. If you had two alike openers with the same color program button, then yes you could program 1 keyless to two or more openers by using different pin's to open the doors
Old 09-29-18, 06:52 PM
W
Will the purple style work with home link car buttons ??
Old 10-03-18, 05:13 PM
W
Will the purple learn button work with home link car
