Garage door opener remote issue
Old 11-16-18, 09:15 AM
Hi - I have a 20 yr old sears garage door opener that doesn't close via any of the remotes - which in the homelink built in a car or the push button remote that came with the opener. Details follow:
Works perfectly will hard wired push button inside the garage, up and down
Raising the door works every time with remotes
Closing the door however is inconsistent - appears to be temp related as in colder (below 40 F) it doesn't work most of the time.
I have verified that a signal is being received as the green LED flashes, I have also taken the logic board out to inspect for any flaws/cracks in the solder but can't detect any.
Just seeing if anyone has any experience with this before I purchase a whole new garage door opener - everything else with respect the unit is in good working order. Have tried to obtain a used logic board but for this model there doesn't seem to be any available, an internet search revealed a site that listed the part no but they were out of stock, no new ones available anywhere owing to the age of the unit.
thanks
Old 11-16-18, 07:38 PM
Received 372 Votes on 349 Posts
Welcome to the forums.
Are you using standard incandescent bulbs in the unit ?
LED and CFL types can interfere with the received signal.
Old 11-18-18, 02:24 PM
Standard bulb. I believe it is a faulty component on the logic board - it will also open using the remote, but in temps somewhere around 40 F or lower it cannot be closed via remotes, the led on the unit flashes to it always gets a signal, but doesn't always execute.
Tried to get a replacement board - Sears wants $89 - too much , liftmaster has a logic board that might be compatible but they say I have to go through sears and to determine whether it's really a compatible replacement - pretty irritating.
A new liftmaster unit is $128 , lowes has a Genie belt drive for $ 168 but I'd just as soon repair my unit if possible.
thanks
