New shed not high enough to open doors completely
Old 03-04-19, 10:26 AM
So I just put up an 8X10 resin shed by Suncast. I leveled the ground and put it on a paver base slightly elevated. What I didn't realize was how much the yard sloped to one side preventing one of the doors from opening all the way (needs 4-6 inches), while the other has a few inches of clearance.
Considering that the shed is a few hundred pounds, I also don't know how feasible it would be to somehow move/raise it, add some height to the foundation and put it back.
I don't like the idea of digging a trench just for the sake of opening the door and then creating water/drainage issues.
Any other creative solutions?
Old 03-04-19, 10:30 AM
XSleeper's Avatar
Received 195 Votes on 181 Posts
Raising it should be easy, maybe you could lay a perimeter of 2" paver blocks for it to sit on. Other idea would be to create a retaining wall on the side that is high... dig down the slope so the door opens.
Received 197 Votes on 182 Posts
Is the door easily removable? If not you could install some simple pin hinges or hinges that you can easily pull/remove the pins. Then you open the door part way and lift it off the hinges and set it aside.
Old 03-04-19, 12:41 PM
Received 3 Votes on 3 Posts
If the shed has its own floor, I would dig out enough dirt to allow the door to open and build a retaining wall. Otherwise, you will need to remove the shed, raise the paver base, and re-position the shed on the raised paver base.
Old 03-04-19, 05:49 PM
Received 29 Votes on 25 Posts
Moving the shed and raising the base is the easiest solution. Invite 4 buddies over for pizza/brew. If you work fast, the pizza won't get cold. Another approach is to use 2/3 10 foot lengths of plastic pipe (under the 8 foot dimension) and roll the shed off and back once the base is raised. Have 2 buddies roll the shed off and the other 2 roll the shed back into place.
Old 03-07-19, 05:51 PM
I can't really picture the retaining wall idea in my head - Can you maybe clarify or share a picture of something similar?
Old 03-08-19, 05:59 AM
I cannot picture your situation in my head. A photo would be a tremendous help so we can help you.
