Genie H2000C
Old 05-03-19, 02:54 PM
Genie H2000C
I have a Genie garage door opener that was not opening all the way. It would open about 3 feet then stop. I tried to fix it and eventually decided to replace the circuit board. After replacing the board the wall switches are not working. The dome light comes on, the green and red sensor lights are on, but the light for the wall switch will not come on and nothing happens when I press the button.
Thanks.
Old 05-03-19, 04:49 PM
Received 477 Votes on 447 Posts
Your original problem sounded like an adjustment issue..... either opening force or upper end stop not set.
Now.... it sounds like a wiring problem.
Does the board have the same exact part number ?
Old 07-01-19, 12:37 PM
PJmax,
Sorry, For the delay in replying. I got side tracked from this project/problem.
The old board was 34513 rev c and the new board is 36189-A.
I put the old board back on and am still having the same problem. The door will only open about 3 feet and stop. Sometimes if I press the wall switch to force it to go up it wall cause it to lose power and the red light will go out at the wall switch.
