Liftmaster garage door opener: remotes not working
Old 08-27-19, 07:22 PM
The 3 different hardwired buttons located inside and outside the garage work fine. Both of my SUVs and all remotes do not work. The Lock feature isn't enabled (no blinking). When using a 'remote' (car/physical remote), the LiftMaster blinks one time and nothing happens. Since the hardwired opens/closes, the motor is operational. Since the LiftMaster blinks using a "remote", then it must be receiving a signal. Where should I start troubleshooting?
Old 08-27-19, 08:42 PM
Received 337 Votes on 315 Posts
What blinks one time...... the big light on the front of the unit ?
Old 08-27-19, 08:47 PM
Yes sir -- The light on the unit.
Old 08-28-19, 04:27 AM
Geochurchi's Avatar
Received 15 Votes on 15 Posts
Hi, on the back of some units there is an LED that will flash trouble codes, have you checked that? What is the model # of the unit ?
Geo
Old 08-28-19, 07:25 AM
Part # on the unit: 41AC050-2M with a 3/17 date so it appears to be new.
Confirmed via video which is odd because it was not consistent:
1st attempt to open resulted in light blinking 1 time and Learn button flashing 3 times. The light turned off with the Learn button flashing 1 time
2nd attempt to open resulted in light blinking 1 time and Learn button flashing 2 times. The light turned off with the Learn button flashing 2 times
Old 08-29-19, 05:48 AM
Geochurchi's Avatar
Hi, I would call Chamberlain tech support, just be prepared to be on hold for awhile, they have been quite helpful.
you are sure itís the learn LED thatís flashing?
Geo
