Why would not everyone get a direct drive garage door opener?
Old 09-14-19, 02:28 PM
Just wondering, why not everyone woudl get a drive drive garage door opener?
I realize that direct drives are recommended for space constraints and low noise. Also, a bit more expensive over belt.
Are there any drawbacks?
Old 09-14-19, 03:36 PM
Norm201's Avatar
Received 61 Votes on 57 Posts
Just $$$___________________________________
Old 09-15-19, 03:31 AM
Doorman2722's Avatar
Received 9 Votes on 9 Posts
They will not work on an extension spring door or a low headroom torsion spring door.
Old 09-15-19, 05:02 AM
Tolyn Ironhand's Avatar
Received 55 Votes on 48 Posts
Typically there is not an outlet located near where the direct drive will be mounted. The Direct drive openers I have wired also will have a remote light that also needs to be installed/powered.
Old 09-27-19, 02:36 PM
I attached an image of my garage. I am assuming the "rod" is continuous and I can attac the opener on the left. I will be removing cabinet.
Old 09-28-19, 10:46 AM
It looks like you have room to mount the opener on the side like you mentioned. You would have to run a power outlet where it's going to be located and you probably would have to wire in the remote light so you had light when you opened the door. The other alternative would be to put the existing ceiling light on a motion detector.
Is there a reason you want to go to a direct drive unit?
Old 09-28-19, 03:50 PM
The kits that I looked at come with a light that is wireless controlled. So I plan to install the light near existing power outlet.
The reason for direct drive. I have a bedroom above garage. So, it woudl need to be belt or direct drive. Direct drive seems superior over belt as it has no exposed moving parts. Still wondering, other than price why not everyone woudl get direct drive.
Old 09-29-19, 08:20 AM
Sister's hubby installs doors and when he built her another garage he used the direct drive. I was really impressed how smooth and quiet it is, very nice.
Old 09-29-19, 04:08 PM
BTW. It looks like there is pretty much only one direct drive model out there. At least the shape looks the same to me whether it is Chamberlain or lift master.
Does anyone know who actually makes them?
