Lift Master Garage Door Not Opening All The Way
Old 09-02-20, 08:42 AM
I have a LiftMaster (41AC050-2M) that goes up a few feet and completely stops. It will go down as expected. I don't notice anything on the track that is preventing travel. If I really push up and help with the travel, it goes all the way as expected. Is this most likely a motor on its way out or an obstruction?
Old 09-02-20, 09:43 AM
I increased the "force" screw labeled "KG" about 1/4 turn and it works perfectly fine. Any idea why an adjustment might be needed?
Old 09-03-20, 03:12 AM
Doorman2722's Avatar
Received 21 Votes on 21 Posts
that's a circuit board number not a model number... many reasons, cold weather, door heavy, Broken spring, door needs to lubricated, it was never set when installed. It should be set around the 5-6 O'clock position
Old 09-13-20, 07:18 PM
Sorry for delay. It's Liftmaster 3280 and its most in the 8 or 9 O'clock position. Works perfectly now but not sure why a change was needed.
Old 09-13-20, 09:38 PM
Received 1,021 Votes on 947 Posts
Usually when an operating problem occurs with a garage door opener... you'd disconnect the door from the operator and operate it by hand to determine if there are any sticking spots or if the door balance changes.
Old 09-14-20, 07:13 AM
I tried that. I disconnected it and then tried to move by hand but it wouldn't move at all. I checked both tracks and I didn't see a blockage. I increased the force from 6PM isnt to 8 or 9PM ish and works perfectly.
