Lift master Garage door trolley issue
I have a chamberlain lift master 1/2hp opener. I’ve set the upward and downward travel perfectly and with door not attached it seems to work fine. When I try to attach the door and open it makes a grinding sound and stops. Also does it if I attach door the up position and try to close. Coupling is good and everything appears to be fine with the mechanical aspect of the motor and drive. Any advice is much appreciated!
Chamberlain makes a lot of openers. Which model do you have? Or, at least tell us if it's belt or chain drive or wall mounted.
Where is the grinding noise coming from? That would be a good place to start looking for a problem. I'm guessing it's somewhere in the power head. It could be a stripped gear or maybe the belt tension is too loose and the belt is slipping on it's sprocket.
I’m sorry it’s a screw type trolley system. The grinding is the trolley itself. The tab the carrier attaches to will travel just fine along the trolley until I attached the carrier arm/door. Then it makes the grinding sound when I try to open or close. The door is balanced and moves freely manually.
Liftmaster model #2220
First I would confirm that the carriage is completely/firmly locked onto the shaft. Don't just pull the cord in that direction but get up there and make sure the lever is fully in the locked position and not sitting partially closed.
Yep I did that after I posted pics. Disconnected the arm from the carriage and ran the opener up and down and it moved the carriage perfectly so it doesn’t like something about the door. It feels balanced staying shut when down, halfway open and then stays up. Nothing has been changed with the torsion springs so I don’t how this issue arose.
if the screw is spinning when the door stops, it probably an issue with the trolley. If the screw stops spinning when the door stops i believe there is a coupler that goes bad.
Sorry for the delayed response. The coupling is good and it will turn the screw and move the trolley up and down the rail if the door is detached. When I attached the door it will not move it up from the down position or down from up. The balance of the door seems to be fine and not too difficult to lift in manual. Certainly would think it would be able to move down from the up position. The screw seems to make a grinding sound either direction.
When the door is connected to the carriage, you hit the button and it doesn't move and makes the grinding sound, is the shaft turning? This will tell if something is stripped in the powerhead or if the carriage is stripped.
Doorman2722
voted this post useful.
I ordered a new carriage track so I guess I’ll find out soon. I assumed that when it travels without the door attached that it was operating properly, but maybe with the weight of the door added the stripped threads won’t allow it to travel. I really appreciate the help, I’ll let you know how it goes.
Well it took a while for the new carriage to come in but it was absolutely the fix. Door is traveling smoothly up and down. I suppose the teeth would bite just enough with the door detached but would not move the door when reattached. Thank you guys for all the help.
