Garage Door Bottom Seal
Old 08-25-23, 12:11 PM
K
Received 4 Upvotes on 4 Posts
Trying to replace the garage door bottom seal.
Useing a vinyl seal and it is too difficult to pull through the aluminum channels. It is at halfway now and can't pull anymore.
Will a rubber seal be easier ?
If not, will replacing the channel make it easier ?
Old 08-25-23, 12:24 PM
Received 800 Upvotes on 703 Posts
you might try using liquid soap as a lubricant. Are the edges of the channel bent?
Old 08-25-23, 12:25 PM
XSleeper's Avatar
Received 1,844 Upvotes on 1,659 Posts
Did you clean the aluminum channel first? Lube it with dish soap or silicone spray?
Old 08-25-23, 01:26 PM
K
Used silicon spray , but looks like the T of the seal is slightly bigger than the gap in channel
Old 08-25-23, 02:48 PM
XSleeper's Avatar
If you got it halfway, it isn't too big.
Old 08-26-23, 07:20 AM
P
Received 2,010 Upvotes on 1,802 Posts
The stripping changes shape and size as you pull on it. I often can only pull the strip in part way. Then I go to the other end and shove/push the strip in. Then after you pushed in from the end move in a couple feet and grab and shove the strip an keep working down the door.
Old 08-26-23, 07:26 AM
XSleeper's Avatar
It usually helps to have someone help you feed it in. If you don't, it catches as you pull. I usually use a 3" hand seamer to pull.
