"Excessive Closing Force" and door groaning
Old 11-15-23, 10:32 AM
O
Received 3 Upvotes on 3 Posts
Just installed a new Liftmaster smart garage opener and I noticed that the door makes groaning noises when it opens and closes, check it out:
https://youtu.be/VqnIqZvWCI4
Also, we noticed that once every eigth or ninth close, the open door retracks after traveling about two feet and remains open. The app complains that there's excessive closing force. I did adjust the torsion springs on my garage and noticed that when opening the garage by hand up to four feet it does slouch down around 2-4 inches. Does that mean it's unbalanced? I was thinking about completely redoing my torsion spings in the meantime; there's two of them and I'm assuming they should have the same level of tension, but let me get your thoughts.
Old 11-15-23, 11:10 AM
P
Received 2,270 Upvotes on 2,022 Posts
Yes, the torsion springs should be evenly loaded. Some have a line painted on them which when tensioned form a spiral pattern to help you keep count.
orielonline voted this post useful.
Old 11-15-23, 11:33 AM
O
I'm guessing to measure the distance of the spiral from the end points? Here's a photo of the them:
If I do a full release and retighten, how many rotations should they have?
Old 11-16-23, 10:04 AM
O
Update:
So, I adjusted the springs. Before they slouched about 3-4 inches at the four-door mark, but now they retract about half inch. 10 or so test runs were all successful.
Not sure if I should just do a full reset of the springs at this point. Do you still recommend it?
Old 11-16-23, 10:35 AM
P
Look at the painted stripe on your springs to see if each is wound the same number of turns.
Old 11-16-23, 10:42 AM
O
I measures the white stripe from the side. It's 6.5 inches on the left, 8 inches on the right. Here's a photo:
Old 11-29-23, 07:35 AM
D
Received 1 Upvote on 1 Post
What is it when groaning opening?
Old 11-30-23, 01:00 PM
O
DownInTN
I think it's the door. Something's going on with the panels. The motor and trolly sound fine as they're brand new.
Old 06-09-24, 07:08 AM
P
Received 2 Upvotes on 2 Posts
Does it groan if you disconnect the trolley from the bar that pulls the door open?
Actually, it sounds pretty quiet to me. I can't hear any groans.
Old 06-10-24, 02:20 AM
Doorman2722's Avatar
Received 42 Upvotes on 41 Posts
Post a picture of a center hinge they look unusual to me, also a picture of one of the rollers, the cheap rollers can cause the door to drag (not move smoothly)
