garage door (manual) tension
have a manual garage door is it possible to adjust tension on the spring so door will raise 4" when unlatched to open
if so some tips would be appreciated the owner is old person on very limited income will be doing for free.
thank you for any help
Hello
If you should make it come up 4" when you unlatch the door how will they get it down to latch it...try and get a garage door opener and install it for them if you contact the right pepole they may give you one to install when they know what you are doing...Good Luck
