garage door opener
Old 11-04-01, 03:53 AM
Guest
Unhappy
Our garage door opener, a Wayne Dalton model 2113, was installed in 1996. Last night when I pressed the button to open it, the light came on and the door opened about one inch, then stopped. When I pressed the button again the light clicked on and off a few times, but nothing moved. There is nothing blocking the sensors. I've tried several more times with the same results, however the door does not move and no sound from the motor. We have had no problems in the past. Thanks!
Old 11-07-01, 11:41 PM
mopat
disconnect the opener from the door--pull the orange/yellow safety release rope. See if you can easily open/close door by hand--manually. It sounds like door is sticking, opener shutting off so as not to burn out its motor.
