garage door leveling
Old 11-12-01, 07:41 AM
Guest
So. I'v installed a new garage door and come to find out the floor is not level but the door frame is square. problem is the door looks screwy.
suggestions?
thanks in advance
Old 11-12-01, 06:29 PM
Jacksprat
Easy, and cheap...
My preferred method for resolving this problem is with bigger bottom seal. There is aftermarket product sold by just about every manufacturer. It just compresses more on one side then the other.
Go back to where you bought the door, or to your local garage door service company, expect about a buck or two a foot.
Good luck
Jack
Old 11-19-01, 08:30 AM
Guest
Stop! If the frame is square and the door is level how does the door look screwy?
Make the door level first the door will work bad if it is not exactly level, put the bigger bottom rubber on to make up what the floor lacks. and please dont ask the door to cure what the cement men have screwed up.
