Shed Floor
Old 03-15-02, 11:43 AM
jhaney
Question Shed Floor
I am going to be building an 8x12 shed. I was wondering what I shoud do for the floor? Should I pour a concrete pad, frame it out with 2x4's or 2x6's and 3/4 plywood decking, or should I just put down some crushed stone? Any ideas or comments would be apprieciated, thanks
Joshua
Old 03-15-02, 08:03 PM
the_tow_guy's Avatar
Received 67 Votes on 56 Posts
Actually, any of the three choices would work fine, they just have different characteristics: crushed shell would likely be cheapest and easiest to install, concrete would be most permanent but a lot of work, wooden would be somewhere in the middle. My personal choice is exterior plywood over 2x6 framing which is what I used on the shed at a previous residence. The ground was uneven and somewhat low-lying also so it was built on concrete piers.
Old 03-15-02, 09:02 PM
Rmen13
I built a shed about a year ago and used plywood worked fine, much easier than concrete pad. and if you ever want to move it go with plywood. I didn't like where i built my shed so I moved it to another place.
Old 03-16-02, 11:25 AM
LOL. Yeah, moving that 2-ton slab can be a first class b****.
Old 03-18-02, 05:54 AM
jhaney
Thanks
