Garage door is not level
Our garage door does not close all the way on one side. The door has wheels that ride in a track on both sides (no opener). It seems obvious that the tracks are not aligned properly. Is there a "trick" to aligning the tracks?
The door track comes in sections, with adjustable bolts. Probably one section ( a verticle one) has come loose and slipped down a little. With your door closed, the side that is up, loosen the bolts and let them slide down or push up which ever way you want and tighten.
