Tearing down an old 2 car detached garage!
Old 06-01-02, 03:27 PM
STuron
Angry Tearing down an old 2 car detached garage!
We are in the middle of a project gone bad. A very dilapitated? two car garage concrete block which we are attempting to demolish is proving to be a challenge.
We thought we would be able to climb up on top of the roof, rip the shingles/nails and roofing rolls off to expose the 1 x 6's? Unfortunatly not only is a triple roof but the 1 x 6's are severely rotted. It appears unsafe to climb on the roof at this point. (as we might fall thru!) there is a small crawl space in the top of the roof, so if we did fall thru I guess the fall would be broken slightly. My benevolant other thinks I need severe medication.
Any suggestions on how to approach this project without using C-4?
Tomorrow we will have to make a decision as the dumpster is only onsight for 10 days!
We have all the windows out, the door off and aprox 6 feet on either side of neighbors.
Thanks for your help.
Suz
Old 06-02-02, 02:02 PM
Removing old garage
Typically unsafe structures are knocked down with a bulldozer. Make sure you check with local authorities regarding any permits for the demolition.
Old 06-03-02, 08:12 PM
Get a ladder, climb up on it, poke ahole in your roof, drop a chain or cable through it fis the cable, secure the other end to your pickup and drive forward. Repeat in 3 or 4 foot intervals. Not a problem, just a big mess. Or if you know someone with a backhoe, then have him stick his bucket through the roof and tear it down. Good Luck
