EROSION -- My Back Yard is Sinking
I have an erosion problem. The problem started when my neighbor re-landscaped her backyard and changed the flow of the water into my property. My backyard is sinking, from the edge of the house to under the deck. There are hholes opening up in the ground! I think the sinking yard may have cracked or broken a sprinkler system pipe, resulting in a constant flow of water into the underground dirt. Whatever the cause, my backyard is eroding away and my deck is stating to slant. I think, but I'm not sure, that I need to dig up the backyard and put in a drain, then re-fill it. Is this correct, or can I just put in a drain and fill over it?
What I need to know is who do I call to get help? A sprinkler system person? I landscape person? A contractor? And how do I get the deck even again?
Thanks!!!!
Thanks!!!!
Hello Chris
Have you talked to your neighbour about the problem? In many regions, it is illegal to alter drainage patterns and watercourses when it affects the water rights or land use of others (especially neighbours).
I'd be inclined to call a Municipal or City Civil Engineer to see if the re-landscapeing has indeed caused the problems in your yard, then take it from there.
If the sprinkler system pipe was broken as a direct or secondary result of your neighbours' actions, you might have a case for them to share the costs of the repair to both the sprinkler and your land/deck.
After you figure out who is responsible, you could go with a reliable contractor who should be albe to suggest the steps necessary for stabilizing your deck and making adjustments for the new landscaping/drainage on your property. You might be dealing with a couple trades - carpenters or structural contractors for the deck and landscapers and/or drainage experts for your yard.
I'm going to copy this thread over to the Law, Outdoor Living and the Garden forums also so that more Members can have a look at your problem and possibly make suggestions. (not sure the email notification will work from people answering in those Forums - Members: this thread originated in the Lawns Forum, so maybe if you posted any suggestions or replies to Chris there, it would help keep everything together for simplicity's sake)
Good Luck
Howie
Good Luck
Howie
Hi Chris,
I too live in Maryland and it IS illegal to have water flow do damage to your yard by your neighbor. I would take Howiek's advice and call the county offices where you live. They might even have to pay for all of it.
Do let us know the end result.
Best of luck,
Newt
Best of luck,
Newt
Water Damage
Feeling a little wet behind the ears? Here's what you should know about water damage, your neighbors and the law.
When water causes property damage -- flooded basements, collapsing retaining walls or soggy gardens, for example -- feuds between neighbors often result. But the legal issues can be as muddy as the mess in your backyard.
Acts of God
The law does not hold landowners responsible for things they cannot control: natural events in which they had no part. But damage is often caused by a combination of factors, divine and mortal. If an act of God and somebody's carelessness combine to create harm, the careless person is liable, at least in part.
Most court cases between neighbors that involve water are the result of runoff and flooding from rainwater.
The "common enemy" rule. In the past, many courts treated excessive rainwater as a "common enemy," damaging property at random. Under this theory, you were expected to take measures to protect your own property from water coursing across the land. Even if a neighbor on higher ground diverted water to prevent flooding and deposited it on you, you were expected to protect yourself from the extra water.
The courts that still declare water a common enemy now impose some restrictions on upper landowners. In New York, you can improve your land without being liable for a change in flow of surface waters, provided you do not resort to drains, pipes or ditches.
The District of Columbia's approach is similar. In a case where a house was flooded with water and mud after neighboring property was demolished and graded, the flooded neighbor lost in court. The work was not unusual or extraordinary.
The reasonableness rule.Today, in almost all other places, when one neighbor alters the land and damage occurs to another, the neighbor is liable for the damage if the alteration was "unreasonable." But what to one neighbor appears perfectly reasonable may not seem so at all to another.
Judges have wrestled with these questions for hundreds of years. In 1886, a court decided that although building a house was reasonable, installing a roof without gutters, which caused a neighbor to flood, was not. Gutters and downspouts that send rainwater gushing onto a neighbor's property are also unreasonable alterations to natural flow.
What about digging a ditch that redirects rainwater onto someone else's property? One neighbor in Wisconsin who did this caused water to stand and erode the other's retaining wall. He was guilty of intentionally trespassing on the neighbor's property. But if the ditch were absolutely necessary to prevent huge harm and the damage to the neighbor were slight, there might be an exception.
In a 1980 Nevada case, development of a new subdivision severely flooded neighbors who were there first, destroying one person's property completely. The developers and the county were found to have acted unreasonably and were liable for the damage.
Some states have laws prohibiting landowners from diverting surface water onto a neighbor's property. Texas, for example, provides that no person may divert or impound the natural flow of surface waters in a manner that damages the property of another by the overflow.
What the Neighbor at Fault
Must Pay For
If a neighbor is legally responsible for water damage you suffer, you may be entitled to:
compensation for cost of repairs and replacements
compensation for expenses such as having to stay at a motel
compensation for mental distress, if you have suffered an underlying physical injury.
reimbursement for medical expenses.
punitive damages, if a neighbor acted maliciously. For example, a man in Vermont built a road and two culverts on his land that resulted in flooding the property next door. When the neighbor complained, he built a third culvert that made the flooding worse. He was also verbally abusive to the neighbor. When she sued, the court not only compensated her for her damage, but also ordered the neighbor to stop the water diversion and to pay extra money to her as punishment for malice.
Judges also frequently order problems to be fixed if fixing them would be easy and inexpensive. Replacing a downspout, clearing away debris or cleaning out a drain creates very little burden on a property owner. Judges are less likely to order someone to remove a retaining wall, relandscape property or redo a culvert.
Homeowner's Insurance
Insurance in water damage cases is tricky. If the water comes into your home from an inside source -- say, from a pipe in the townhouse next door -- your ordinary homeowner's insurance should come into play. Contact your agent; your company may pay for your damage and then go after whoever caused it for repayment.
When the damage comes from outside rising water, even if your neighbor's action caused the problem, you may need flood insurance to involve your own company. However, if the problem was caused at least in part by a neighbor, your neighbor's company may well pay you directly. That person's insurance company might also tell your neighbor to correct the problem -- or risk cancellation of the insurance policy.
Copyright © 2002 Nolo
Water Damage. Neighbor Law. Nolo Law For All. Retrieved 26 October 2002. http://www.nolo.com/lawcenter/ency/a...E8D66498A911D7
Acts of God
Must Pay For
Chris,
I feel for you! I live in MN on a pond and the same thing happened to me when my neighbor put in a fence and some landscaping in the swale leading from the street to the pond. Lucky for me it only affected my perennial garden and caused some minor erosion on the side of the house. It is illegal in MN to change the flow of H2O , especially after the city has paid for engineers to determine the flow of water that best works for developing the land long before your home is even built. You might want to go back and find out a little more about your property before it was built on. It sounds like something more could be going on here.
Your problem goes a little further then that though. You have to fix a problem that your neighbor created and still live next door to them! You didn't say if you had discussed this with them yet, but I would hope they see what they have done and take responsibilty for it. Best of luck to you!
