Sending jpg images: what's the max size ?
Old 05-29-03, 09:12 PM
BobLightbourne
I thought I'd successfully attached a jpg image to my last post... the browser appeared to allow this in a box toward the bottom of the page marked "attach file"... However, the jpg image I sent, with a size of 27KB, did not appear when I checked my post.
The browser "attach file" box was marked "Maximum 2 bytes", which is presumably either error or humor... What's the true maximum ? 2KB ?
Old 05-29-03, 11:54 PM
magister
The attach file feature is disabled; You can insert an image using the IMG button or you could insert a link via the HTTP:// button, both of which are located immediately above the composition field or you could insert either, a link or image using HTML; And because the file must be housed somewhere else, such as on your own website or webspace, there really isn't any maximum size except you wouldn't want it so big that folks on dialup would have time to make a sandwich while it downloads from your server.
Hope this Helps;
R
Old 05-30-03, 08:16 PM
BobLightbourne
Thanks for the tip... Prob is have never established own website... Maybe this'll make me do it...
Regards
Bob L.
