Garden Phlox turning yellow
Just planted some gorgeous garden phlox about a week or so ago. Threw some peat moss in before I planted them and gave them plenty of water after planting. The bottom leaves are starting to turn yellow. Anyone know what causes this and how to correct - or is it normal for these?
Thanks
Thanks
Phlox
Hi Bogey,
Phlox likes plenty of moisture but not soggy soil. My Phlox does the same thing in wet weather. I don't know how you prepared the soil, but if you have heavy clay soil and added peat you may not have adequate drainage. Leaf blight can also be a problem with phlox.
Good Luck!
Good Luck!
Thanks for the reply Wilson. The plants seem to have made it through so far. Is there something I should look for/do to contain leaf blight? I have been picking off the blooms as they die away (deadheading?) - is that the correct thing to do?
