a tomato plant
Old 08-05-04, 05:12 PM
smackann
a tomato plant
I bought one little tomato plant that I am growing in a 18x14 (circumference by depth) container on my back porch. You see, I am surrounded by cement in Philadelphia, PA. Anyway, the thing has grown immensely. When I purchased the pot at Franks, they recommended 12 inches. I went with the 14 inch and just today while checking the moisture of the dirt, I felt roots (I only went down about 3 inches). Am I to transplant this monstrosity again? If so, how do I do it? By the way, this is my first experience with growing anything.
Old 08-05-04, 05:18 PM
I would leave it so it will produce. Moving it now will probably keep it from producing, if it has not already done so.
Once a tomato is transplanted from a pup in the spring, it should be where it will stay for the season. A 14 inch pot is probably big enough, if you keep it fed and watered. Next season, choose a larger one.
Hope this helps.
