Tomatos Brown on Bottom - Help!
Hi all! I'm in the Pacific NW and am having a problem with my Tomatos. This is my first year gardening, but even the seasoned gardeners that I've spoken with don't know what's going on in my case. My tomatos are turning brown on the bottoms. The tomatos and not the actual plant. It's a dark brown and it's covering the bottom. They're still green and I found it on one (which I then removed) and now it's on a couple more. Any idea what the problem is, or better yet what the solution is? Any help is greatly appreciated. Thanks!
It's called Blossom End Rot and is caused by a lack of Calcium in your soil. I had the same problem and added lime to the soil immediately and lucked out. No more rot. The nursury said it may not work since the tomatoes were already growing. You will have to sprinkle the lime around the base of the plants and scratch it into the soil with a garden claw tool and then water it in. If you plant more tomatoe plants this year or even next year, till the lime into the soil first. Good luck with your garden.
Here is a rundown on blossom end rot from NC State:
"Blossom-end rot of tomatoes is a physiological disorder caused by a lack of sufficient calcium in the blossom end of the fruit. This disorder results in the decay of tomato fruits on their blossom end. Dry brown or tan areas the size of a dime, that grow to the size of a half dollar, characterize this disorder. This disorder is usually most severe following extremes in soil moisture (either too dry or too wet).
To reduce blossom-end rot in tomato, implement the following steps:
1. Lime tomato soils to pH 6.5 to 6.7 -- Home gardens not limed in the past 2 to 3 years will need 2 cups of lime for each plant. The lime should be worked into the soil 12 inches deep. To determine the exact amount of lime, send a soil sample to the NCDA&CS Agronomic Division, 4300 Reedy Creek Road, Raleigh, N. C. 27607-6465 for analysis and recommendations.
2. Fertilize properly -- Applying too much fertilizer at one time can result in blossom-end rot. Following soil test recommendations is the best way to insure proper fertilization. For home gardens not soil tested, apply 5 pints of 8-8-8 per 100 ft of row and work it thoroughly into the top 8 inches of soil.
3. Mulch plants -- Use straw, pine straw, decomposed sawdust, ground decomposed corn cobs, plastic, or newspapers. Mulches conserve moisture and reduce blossom-end rot. In extreme drought, plastic may increase blossom-end rot if plants are not watered.
4. Irrigate when necessary -- Tomato plants require about 1.5 inches of water per week during fruiting. This amount of water should be supplied by rain or irrigation. Extreme fluctuations in soil moisture result in a greater incidence of blossom-end rot.
5. Spray calcium -- The plants may be sprayed with a calcium solution at the rate of 4 lb of calcium nitrate or calcium chloride per 100 gal of water (or 4 level Tbs per gal of water). This spray should be applied 2 to 3 times a week, beginning at the time the second fruit clusters bloom. These materials can be mixed with the spray that is used for control of foliar diseases. Chelated calcium solutions also provide an excellent source of calcium. When using these chelates, follow label directions. Several foliar spray materials containing calcium are available and all work well for tomatoes."
