Soaker hoses clogging up?
Old 08-03-06, 03:32 PM
We have some soaker hoses that are 4 or 5 years old. I've noticed that the water comes out mostly from the front end (connected to the hose), and comes out at a much slower trickle near the back end (where it is capped off).
My two questions are: what causes this, and more importantly can I fix the problem without going out and buying 8 new soaker hoses?
I am guessing that either dirt or mineral deposits from the water are clogging the pores in the hose.
Thanks in advance!
Mark
Old 08-03-06, 05:34 PM
T
Received 1 Upvote on 1 Post
The downside of soaker hoses is that they can become clogged with soil and calcium from water. Hoses can be soaked in a descaler solution. Usually an annual soaking and cleaning of soaker hoses in vinegar and mold soap solution keeps holes open.
A couple times a season, flush hose with running water through hose with end cap removed. If mineral deposits are a problem, thee are drip irrigation filters available that can be installed and buried or covered over with mulch.
Old 08-04-06, 10:17 AM
Thanks for the advice. I'll try soaking them in vinegar, and an occasional flush as well. If that doesn't work, it's time to get new soakers, preferably a type that won't clog.
Thanks again,
Mark
