Poor soil treatment
Old 09-24-06, 03:10 AM
Poor soil treatment
Living in Spain retired from the U.K. I find that soil quality should more realistically be considered as clay quality.
Having recently rebuilt an old house, I have ended up with a small garden area 5mtrs x 7 mtrs. and subsequently ordered top soil to fill the area to a depth of 40 cm. When it arrived and was tipped I realised the soil was more of a clay consistancy than the top soil we are used to in the UK.
Can anyone please advise me on what I can do to treat this "soil" in order to break it down into a more acceptable form. Large bags of peat, sand etc are available and I am wondering if I mix these with the delivered soil I can get a more acceptable mix. If so in what quantities, and if this thinking is correct what else should I be mixing with it.
Thanks in advance for any info forthcoming
Old 09-24-06, 08:39 AM
Hi Dobo,
Congratulations on your new home. One of the best things you can do for your clay soil is to add compost. It will improve the tilth (texture), improve drainage, add nutrients and good microbes. An inch of sand and 3" of compost applied on top and then mixed in will greatly improve your clay soil. Leafmould would also be good if that's available. Here's some info on soil and a compost calculator.
http://www.cedar-grove.com/calculator.asp
http://www.pbs.org/wgbh/victorygarden/knowhow/pp/soil.html
http://www.rhs.org.uk/advice/profiles0104/peatfree.asp
http://www.rhs.org.uk/advice/profiles0106/soiltype.asp
Newt
I wouldn't add peat as it is low in nutrients and once dry is difficult to rewet. Here's some info on peat.
http://www.rbgkew.org.uk/ksheets/peat.html#help
Old 09-24-06, 02:17 PM
Newt, you're pretty good! Timely, acurate.
Dobo...if you have the room for it, set up your own compost bin. If done right, you could have two batches of black gold a year created by your own yard and kitchen waste.
Do what Newt says, adding as much of the mulched leaves this fall to your soil and tilling every two weeks until just before frost.
Top with 4-5 layers of newspaper and hardwood mulch or shredded leaves late in the season or after planting.
Your new bed will be ready for show by Spring.
