How to graft fruit trees and grapes
Old 10-13-08, 07:46 AM
G
I have a few fruit trees and vines that I would like to graft.
At present, I want to graft a cutting of a good seedless grape to the stock of a sweet grape that has seeds.
Knowing very little of the subject, I was going to take a few cuttings (old cane or new?)and attempt a graft. I planned to cut the stock back to approx 8" above ground and seal off where I made the cut with a very soft plumber"s putty.
Using drill bits about the size of the cuttings, I had planned to drill several holes in the stock and insert the tight fitting vines into holes and seal with putty as well.
Am I anywhere close?
Should I wait until the leaves fall or while the cuttings are green?
If I am all wet, then please tell me how it should be done. Tom
Old 10-18-08, 01:51 AM
N
Hi Tom,
Here's some methods for grafting. This first one will give you an overview of the different types of grafting.
http://www.homeorchardsociety.org/article/41/
This is for your grapes.
http://berrygrape.oregonstate.edu/an...ng-grapevines/
Pics and info on the different techniques described in the first link.
http://aggie-horticulture.tamu.edu/p...opagation.html
Lots of info on rootstock, etc. here.
http://bluestem.hort.purdue.edu/plan...pagation&-Find
Newt
