Tree Leaning from Tornado
Along with a lot of other issues (my roof is gone) I have a 30 feet tall Bradford Pear tree (trunk about 12 inches around) that is leaning about 20 degrees from our recent tornado experience. Only a few small branches were broken and the tree looks otherwise quite healthy all things considered. How do straighten it up without damaging the tree before the list becomes permanent?
Your're going to need something very heavy and with a winch. Not shilling for tow companies here, but you could probably get your tree straightened for about 50 bucks. Unlikely you'll upright it with an SUV unless it's an H2.
That's a good idea. Maybe I can call AAA. LOL. The local "tree company" estimated $200 for them to come out and get the tree vertical again. I will call a wrecker service and see what they can do. Did you stake the tree heavily after pulling it straight? I am concerned it will just drift back into the underground void that may be created.
Not everyone will be willing to do it, but someone will probably take the job.
The tree guys estimate, did that include the bracing? If so it may be worth the extra cost.
The palms I did the howeowners braced them up with diagonal 2x4's.
Hi Jjjedlic,
So sorry to read about the damage to your home. You will need to make sure that major roots aren't severed. Here's some helpful links about storm damaged trees.
http://edis.ifas.ufl.edu/pdffiles/EP/EP29100.pdf
http://hort.ifas.ufl.edu/woody/whatwelearned.html
Newt
Newt
So far the wrecker guys aren't interested, but still working on it. I don't understand the bracing you described. Did the just wedge a 2x4 behind the tree at an angle? Sorry I am a little slow and having trouble picturing this.
How to brace/stake/guy a tree.
http://hort.ifas.ufl.edu/woody/staking.html
http://www.rhs.org.uk/advice/profile...king_trees.asp
How to stake/brace palms.
http://edis.ifas.ufl.edu/LyraEDISSer...ment_version=1
Newt
Newt
The ones I saw were mostly like newt's link on palm trees, although mostly people just wedged them without creating an anchor around the trunk.
Your wrecker guys must not be very adventurous; I hardly ever turn down a job that's slightly out of the ordinary.
Have you tried hiring your local wrecker by the hour? I have hired wreckers to do unusual jobs and found it better to not get too specific with the person who answers the phone. They sometimes think you are "trouble" and will end up taking a lot of time for a minimum/standard tow fee.
You want to make sure you get the equipment you need (how much cable length, how much pulling force...). A couple times I have gone to the wrecker site to talk to the owner/operator and explain what I am doing and we pick the correct piece of equipment.
They have never turned any job down. Sometimes they say "that's no problem" and sometimes they say "I'll give it a try and see what happens". Keep in mind that the wrecker is a business and they have to make money. Do not waste their time and be clear that you will pay for their services.
