how to care for cactus
Old 04-06-09, 05:15 PM
Hi all, I have a cactus that I recieved from my grandmother after she passed away and have no idea how to care for it. I gave it some water and now it's going limp. Is there anything I can do or did I drown it? Oh ya I've never had a plant so you might need to type slow so I understand.
Thanks Chet
Old 04-06-09, 05:46 PM
Gunguy45's Avatar
Super Moderator
Cacti require very little water. But normally lots of sun. I knew someone that took one from Texas to the North..and they checked the weather report for rain where they got it.
Needs well drained soil...and prob a bunch of other stuff I don't know. Here they grow in sand and rock with maybe 3" of rain per year!
I need to learn about them as well.
Old 04-06-09, 06:06 PM
I had a few cactus a number of years ago. Do you know what kind of cactus you have?
I would find a southern facing window that gets lots of sun and put it there. I watered my cactus every few weeks with very little water. You can also get a succulent fertilizer at your local garden center.
Old 04-06-09, 06:56 PM
Thanks for the help, I have no idea what kind it is.
I have it in a south window and didn't give it much water so we'll see what happens.
Old 04-06-09, 07:37 PM
Hi Samuari,
Sometimes people call a plant a cactus and it isn't. Can you post a link to a picture? I suspect you may have a Christmas cactus aka Schlumbergera. Does your plant look like this?
http://www.desert-tropicals.com/Plan...ra_Nicole.html
Newt
Old 04-06-09, 08:34 PM
It looks different, I have the day off tomarrow it might take me that long to figure out how to post a pic.
Thanks
Old 04-06-09, 10:22 PM
Samuari, you are very welcome! You can post pics at a free site like photobucket.com and post the link to them here.
Enjoy your day off.
Newt
Old 04-07-09, 09:17 AM
Ok that was easy
Old 04-07-09, 12:14 PM
Great picture. It's a true cactus but I'm not sure which one it is. There are cactus that grow like that. Here's an octopus cactus.
http://www.hotgardens.net/Octopus_ca...amonsensis.JPG
Your soil looks very dry. I would say to take it to the sink. Let the water run slowly until it runs out through the drainage holes. Let all the excess water drain off and put it in a bit larger saucer. Keep it in full sun and turn it every couple of weeks. Water when the top of the soil is dry. Most cactus grow in conditions where there is intense rain and then drought. If it were to be wilting I would think you would see wrinkling along the stems.
Newt
Old 04-07-09, 06:52 PM
Thanks Newt, I'll water it tonight. I only gave it about 1/4 cup then after that it started ti go limp so I figured I drowned it. There are no holes in the bottom so I will drill some.
One other thing I thought of is it was out in 20degree temps for about 20 min would this affect it at all.
Old 04-07-09, 07:31 PM
If there are no drainage holes then you MUST add those before you water again, especially if you are going to run the water through as I suggested. And 'yes' that cold of a temp for such a short time can effect it.
Newt
