Moss
Old 04-04-00, 08:01 AM
Post
How do I remove moss from patio. I have a small section of patio blocks which are covered completely with moss and am looking for the easiest way to remove it.
Old 04-07-00, 11:36 PM
Post
The easiset way to remove the moss is with a powerwasher. You can rent one at a local rental yard.
Old 07-28-04, 07:46 PM
steelee2
Thumbs up
After you use the power washer, if indeed you do, try treating the area with bleach as it is a deterrent to moss.Can be used in lawn situations too.
Good luck
Old 07-30-04, 10:12 AM
Using bleach 25% in water will kill the moss. Spray it on, let it sit, and rinse it off for maintenance.
