Chickweed
Old 08-06-00, 07:33 PM
Guest
Angry
Help. Chickweed overcoming garden, but I don't want to spray chemicals so close to the garden. Any organic deterents?
Old 08-06-00, 08:23 PM
Ladybug
Wink
I understand yuor reluctance to use chemicals. Me too. The key to controlling is get them early - don't let them set seed. Hand pull or cut off from roots and remove from property. I'll swear those plants continue to develop seed after the plant is pulled. If you just lay them on the ground they will re-root. Don't chop up with a hoe - it just makes more plants.
You can also use barriers - mulch, landscape fabric, etc. Be sure to keep after any plants which appear.
There is no easy way but if you go after them 1-2 times a week starting early in spring you should be able to keep on top of it. After a few years there won't be such a bad problem.
