making a stand for a barrel compost
Currently, I have a barrel compost setup that the barrel rotates on some casters. To get it off the ground, I was thinking of making a stand along the lines of the above. The stand would be about 2 - 3 feet tall. I'd planned to cut up a scrap bed frame. Where I've hit a snag is other than welding, how to hold the metal pieces together. I thought about drilling holes and using nuts and bolts. I've also considered pop rivets. Any suggestions?
Once mounted on the frame, how will the casters interact with it to allow rotation of the barrel? Using a bedframe, you could use holes with nuts and bolts (a couple per plane) to hold it together, if you have no welding experience. I would make a bottom frame similar to the top to keep it from driving itself into the ground. In other words, a box of steel angle.
Nuts and bolts, yes. Pop rivets, no.
For the bottom frame that Larry is suggesting, I would use some wide angle iron -- something about 2" X 2". Also add cross braces (top corner diagonally to the opposite bottom corner) on all 4 sides to keep the frame from collapsing.
Why not use wood?
Is there any reason you don't want to use wood? The bed frame might well start to rust in a short period and is also probably more difficult to assemble. Simple pressure-treated construction lumber might even look better too. And you can more easily attach the casters or rollers.
Thinking of it, I might just make a compost barrel like that myself. Great idea!
Cheers! MM
Cheers! MM
