Topping Blue Spruce
Old 07-30-14, 05:37 AM
Geochurchi's Avatar
Received 25 Votes on 24 Posts
Topping Blue Spruce
Hi all, I need some suggestions for the best way to top a 20' blue spruce that is getting to tall for the location.
Geo
Old 07-30-14, 02:47 PM
Received 33 Votes on 25 Posts
So-called "topping" of a tree usually results in killing the tree. If you MUST do it be sure to cut on a fairly steep angle and then seal the cut end. Otherwise the tree is almost guaranteed to rot from the top down.
Old 08-02-14, 07:36 AM
Received 2 Votes on 2 Posts
Most are shaped like the classic Christmas tree, a triangle. Lop much of the top off and it will look ugly imo.
Old 08-18-14, 04:17 PM
Received 4 Votes on 4 Posts
It will be tricky to make it look good. Why not cut it three feet from the ground and make it hedge-like and you can prune it to your taste. Probably you will end up pulling it out or cutting flush with the ground.
