Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Gardening and Horticulture
Reload this Page >
Bottom step of deck dilemma --- suggestions?
Old 05-04-16, 09:01 AM
I purchased my house last fall and had a deck built. The guys who built the deck didn't put a concrete pad or any kind of a landing at the bottom of the steps. When the city inspector came out to inspect the deck, he told me that I need something there because as it is, the stepdown is 9 inches while the steps are 6 inches from each other. The previous owner put a ton of pea gravel in the backyard play area, so I was thinking of building a patio with the pea gravel. Only problem is that 3" deficiency. That's a lot. I've never done this before. Any suggestions (other than having the deck builders come back). Thanks.
Old 05-04-16, 09:12 AM
P
Received 606 Votes on 559 Posts
You can place pre-cast concrete step stones or pavers. I've seen them 2" and 4" thick. You could also build a border and fill the interior with stone to get the height you need.
Old 05-04-16, 09:20 AM
XSleeper's Avatar
Received 644 Votes on 596 Posts
What are the stair stringers setting on? Dirt? I hope he put them on piers. if you don't want to pour concrete, pavers are a good idea. If you don't want pavers... then the border idea is a good one... that way the border of your landing area could be made level, 6" from the tread... and the border will hold the gravel.
Personally I wouldn't want gravel right off the deck... some of it is sure to get tracked onto the deck which will eventually dent and scratch it.
Old 05-04-16, 10:43 AM
Received 75 Votes on 70 Posts
Also pea gravel will not compact.
If those stringers are just sitting in the dirt there going to settle and rot out.
Old 05-04-16, 11:04 AM
Thanks for the ideas, everyone. The guy who built the deck did put the step posts on piers and overall, the building inspector said the builder did a great job -- he just left too much distance between the bottom step and the ground. The inspector was the one who suggested moving some pea gravel over to the step area, but I definitely like the idea of pavers better. Thanks!
Old 05-04-16, 11:53 AM
W
Received 17 Votes on 16 Posts
Steps
I would suggest a concrete step at the correct height. Dig out so the step will be uniform thickness, build a form and place the concrete.
Old 05-04-16, 12:18 PM
C
Received 89 Votes on 68 Posts
IMO pouring a pad for the step is probably the best fix. If you go that route pull the bottom treads off the stringers for better access.
I once built a walkway with pea gravel. Not a good material for this purpose. As someone else posted - it doesn't compact. I ended up installing field stone and using a bit of the pea stone mixed with paver base to fill in between the stones.
