"Making Flower Pots"
Old 04-20-01, 05:44 AM
Lightbulb
I have seen this tecnique used some years ago, you mix cement, peat moss and ??? to make a unique flower pot. I remember you must line your form with plastic, a hole is put in for drainage, the mixture is then put into the form and left to dry. When dried you take it out of the form and you now have a flower pot. A metal brush is used to soften the edges and smooth it out. Said to spray it with beer and you could cover it with moss.
I have no idea of the exact measurements or the third ingredient. Any one out there who knows and will share this with me will be appreciated.
Old 04-27-01, 08:33 PM
Thumbs up
ingredients are:
1 part sand
2 parts peat moss
mix together then add
1 part cement mix
add water to make a wet mud
line the mold with plastic
dont forget a drainage hole, use a stick or dowel rod
Old 04-30-01, 05:42 AM
Flower Pots
Thank you so much for the reply from the guest, Ginnco.
Old 05-07-01, 09:37 PM
Gami
This is a GREAT link for hypertufa pots. You can make birdbaths and numerous other things -
http://home.flash.net/~blhill/pages....d/recipes.html
Gami
