Advice on shovels
Received 0 Votes
Advice on shovels
I'm new at gardening and have just got a small community garden bed. I'll mostly be planting vegetables and will be getting a pointed shovel.
Would like guidance on the shovel length: The beds are about 1' off the ground.
My back can sometimes get strained. I have a choice of 2 shovels--one is about 3' long and the other about 6'. Recommendations?
Welcome to the forums! A full size shovel may not be what you need, anyway with it raised off the ground. Will you be standing in the raised bed to till it or along side? Control wise and considering your back problems look into a D handle shovel. Easier to handle and not too long. HDX 10.75 in. D-Handle Utility Shovel-2531800 - The Home Depot
I have raised bed garden beds. If there is real digging to do like turning the soil or mixing in compost I stand in the raised bed and use a shovel with a long handle. This allows you to stand more vertically and use your foot/leg to push the shovel into the ground minimizing strain on my back. Once the soil in a raised bed is ammended and being planted or worked each season it doesn't get compacted and hard so the rest of the time I just use a hand trowel.
I generally only go for a shorter D handle shovel when I need to do more precise digging like making a hole or trench with nice flat bottom. The shorter length and D handle give more fine control over the shovel face but also tends to force me into a more hunched over position and I use my upper body more.
