Which basics to connect 3/4 poly to hose
Old 06-19-17, 07:30 PM
I want to have some valves controlled by a controller wire. The other end of the valve will be hose connected to a sprinkler because the hose part is only temporary but I need 4 different zones.
Is there a valve to connect from 3/4 poly to screw hose on the other end?
Old 06-20-17, 05:36 AM
You can use a 3/4" barb to 3/4" male hose. They are available in brass and plastic.
It helps if you heat the end of your poly pipe with a hair dryer, heat gun or torch to soften the plastic. Inert the barbed fitting and secure with a couple hose clamps.
