Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Gardening and Horticulture
Reload this Page >
Removing old tree roots that keep destroying my ride on mower deck?
Old 04-21-21, 09:35 AM
Received 1 Upvote on 1 Post
Hi, what tools would I use to remove roots that I forget about which keep bending my riding mower deck when it runs into them?
An axe? If so, what type? Never had an axe before. Thanks.
Top Answer
04-21-21, 10:49 AM
XSleeper's Avatar
XSleeper
XSleeper is online now
Received 1,712 Upvotes on 1,536 Posts
I'd probably use a cordless sawzall and pruning blade.
Old 04-21-21, 10:16 AM
P
Received 1,766 Upvotes on 1,579 Posts
Any kind of axe will work. You can usually find them at yard sales for a few dollars.
Old 04-21-21, 10:49 AM
XSleeper's Avatar
2john02458, YaddaYadda voted this post useful.
Old 04-21-21, 04:38 PM
Norm201's Avatar
Received 672 Upvotes on 595 Posts
Even a hand saw will do the job._________________________
Old 04-22-21, 06:31 AM
W
Received 60 Upvotes on 52 Posts
Single bit is safer than double bit. Felling ax. You will need to sharpen often as chopping into the dirt will dull the ax quickly.
Old 04-22-21, 06:41 AM
Norm201's Avatar
Don't use a chain saw._____________________
2john02458, I Mullins voted this post useful.
Old 05-04-21, 10:04 AM
Thanks for the warning to avoid a chainsaw as I do have a few of those actually. What will happen? Would it kick back?
I do have a sawzall but it's corded actually. I could run an extension cord to the location pretty easily unless there are some why nots you have in mind.
I see pruning blades on Amazon. I haven't used my sawzall too much. Will it just go into the ground there and cut out the roots with no hassle? Wouldn't it kick back as well?
Thanks.
Old 05-04-21, 10:48 AM
2
Received 318 Upvotes on 272 Posts
Check this thread for some related information and pictures. With the Sawsall I can cut along the lines of the pavers to separate the roots.
In addition to potential kickback a chainsaw will throw bits of stone, dirt, sand, etc. everywhere and the teeth will be dulled to uselessness immediately.
The several reciprocating saw blades that I destroyed were all-purpose wood/nail/metal cutters. Rocks and dirt in addition to the hardness of the roots wore them down. I currently am using blades labeled for wood/plastic/pruning and they work much better, have larger teeth, and last longer.
Kickback from a reciprocating saw is more likely to bend or break the blade than jump into your leg or foot. (Or maybe dislocate a shoulder if you are too rigid and not quick enough.) Cutting from the bottom up and levering the saw against a fulcrum can avoid such problems. In any case wear eye protection. A long crowbar (6 ft.) will also be useful to lift the main root and get to others that sometimes grow down from the main root.
Norm201 voted this post useful.
Old 05-04-21, 11:09 AM
Norm201's Avatar
Not mention that a chain saw will be dulled almost immediately.
Old 05-04-21, 01:55 PM
2
But I did mention it .
Old 05-04-21, 05:09 PM
Norm201's Avatar
I read right over that part.
Old 05-04-21, 08:09 PM
Y
Received 22 Upvotes on 21 Posts
You don't HAVE to remove the entire piece of root. You can get low to the ground ...and hold the sawzall parallel and shave off the portion above the soil.
2john02458 voted this post useful.
