Young maple tree help please
Old 06-12-21, 06:50 AM
Received 1 Upvote on 1 Post
Hi, I planted a young maple tree late August 2020. Everything was well after plantation. I live in north east. Fast forward may 2021, it bloomed 2nd week of may. After 2 weeks it started to get stressed I assume from the hot and windy weather we have been having. I've been watering it every 3-5 days as it stared to look dry and brown leaves (see photos).I check the soil so that it is nor saturated so I assume i am not overwatering ( I hope). The soil seems semi moist after only 1-2 days after watering (slow for 45min). I dont know what's going on. This is the second tree that had issues in my front yard (I'm starting to think it is bad soil?). Anyone have an idea what I am doing wrong? Thanks
Old 06-12-21, 09:13 AM
Received 3,415 Upvotes on 3,063 Posts
Look closely at the back of the leaves. Do you see any insects?
In the Northeast we have aphids and caterpillars.
Old 06-12-21, 11:56 AM
I haven't seen any insects.
Old 06-12-21, 12:33 PM
2
Received 314 Upvotes on 268 Posts
Guidelines that I received for a new tree included: Make sure the plant's roots are saturated before installing the plant and when watering ensure water penetrates soils to the depth of the root ball. Based on size your tree looks like it should get 8--12 gallons per application. The soil should be built up in a circle with a berm at the outside to contain the water. If 8-12 is too large and overflows then water 2-3 times each application to get full amount.
Water new trees every other day for first two weeks. Once soil is saturated limit watering to once a week. Watering schedule should be followed throughout the first full growing cycle (Spring-fall, late fall until freeze).
I bought a hose timer and set the schedule to automatically apply the water.
Also be aware that newly planted trees and shrubs take 3 years to establish: First year sleeps (recovery), second year creeps (roots spread), third year leaps (plant grows).
Old 06-12-21, 02:04 PM
Thanks for the information. I just called the tree nursery and they advised me that the issue is it probably didn't get enough water going into the winter so in the spring with the hot weather the issue was already present. Seems to make sence. I will be going to see them to get further advice. Thanks
2john02458 voted this post useful.
Old 06-12-21, 03:31 PM
XSleeper's Avatar
Received 1,701 Upvotes on 1,525 Posts
What's on the bottom 6" of the trunk? My first thought on looking at the photos is that it looks like it was planted about 8" too high.
And I think a good possibility with the leaves is herbicide drift from lawns getting treated... and everything stated previously is also a possibility.
Old 06-12-21, 04:04 PM
Soil is heavy clay so it is planted about 3- 4inch above grade. There is mulch over the base of the tree.
