Dying evergreen
Old 06-11-22, 09:08 PM
T
Received 1 Upvote on 1 Post
Dying evergreen
I am in Toronto Canada. I have six evergreen trees in my garden. They were already there when I moved in to the house a couple of years ago. I don't know how old they are. But they are probably about 20 feet tall. Recently, I noticed that 5 out of the 6 trees, the needle (leaves) of the lower part of the trees are turning brown and some branches has all the needle leaves shed. I am not sure if the trees are sick. I noticed that right next to the evergreens that are in trouble, less than a feet from the trunk, there is another tree (not evergreen) growing strong and healthy. They are not tall or big enough to cover the evergreen. Is it possible that the weak evergreen is caused by the strong growing tree right next to it ? What can I do to save the evergreens.
Every evergreen in trouble has a tree next to it growing strong and healthy
Old 06-12-22, 03:41 AM
Received 1,188 Upvotes on 1,146 Posts
Yeah, that looks like a weed tree to me - I cut them down.
Old 06-12-22, 04:41 AM
Shadeladie's Avatar
Super Moderator
Received 343 Upvotes on 274 Posts
I'm not an expert, but it doesn't look like an evergreen to me. AFAIK and from experience, there's not much you can do when a tree starts dying except cut them down and plant new ones.
Old 06-12-22, 08:26 AM
T
I am no expert either. I think it is a pine tree.
Old 06-12-22, 09:08 AM
Shadeladie's Avatar
Super Moderator
Well no it’s not. That I’m sure of.
Old 06-12-22, 11:54 AM
Marq1's Avatar
Received 1,101 Upvotes on 1,001 Posts
Get a close up of the leaf and google the picture, it is definitely not a pine/evergreen!
Old 06-12-22, 12:00 PM
P
Received 1,764 Upvotes on 1,577 Posts
The trouble is your photo shows the parasite tree much better than the tree you want to save. Can you post a closeup of a branch of your evergreen so we can try to identify it.
Having the other parasite right next to the desirable tree is a big problem. Eventually the stronger will win out and the other will die. I would cut the weed, deciduous tree down. The minute it hits the ground heavily paint the top of the stump with glyphosate (RoundUp) concentrate syrup. This will kill the roots and prevent it from sending up sucker for the next several years. Then maybe the desirable tree can recover since it's not competing for nutrients and water. Even if it has a disease not having to fight for resources can make the difference.
Old 06-12-22, 02:18 PM
Shadeladie's Avatar
Super Moderator
I actually see two trees in the pic, but neither is a pine, as far as I can see.
