Winterizing sprinkler system
Old 11-10-01, 06:47 AM
Guest
Smile
Hi all,
Quick question: How do I winterize my sprinkler system?
Any advice/tips appreciated.
Thanks!
Old 11-12-01, 04:38 PM
Gami
Hi TumblingYak,
If someone installed it for you, they should have given you a manual or instructions on what to do.
I don't have one, but it sounds like all systems are different. Some you need to blow compressed air through the lines, and in certain areas that's not necessary.
Check with your landscaper, or try searching for the kind of system you installed if you did it yourself or check with the store you bought it from.
In the meantime, here are a couple of links, but you can get more information by searching for "winterizing a sprinkler system".
http://www.rainbird.com/consumer/man...components.htm
http://www.trendmakerhomes.com/services/winter.shtml
Gami
