Working on a Reznor Xl105-3 need manual or help wiring this up!!
Old 08-23-15, 01:59 PM
P
Hello, I just purchased a Reznor XI105-3 unit heater and I need help wiring it up! I knew it worked at the time of purchase but, when I picked it up everything wasn't wired so I have no idea where to start on the wiring. Any help would be much appreciated.
Thanks Robert
Old 08-23-15, 02:58 PM
Received 926 Votes on 865 Posts
Welcome to the forums.
Trying to get a wiring diagram or manual for these units is like pulling teeth.
Wiring them is fairly easy.
There should be a wiring diagram on the access or wiring cover. Do you have that ?
Old 08-23-15, 08:23 PM
P
No I don't, the wiring cover the person took off and all the wiring are not connected to one to the other or where they should go,So I am at a loss right now
Here is the wiring that is in the fan box
fan wires brown with yellow stripe and brown with black stripe both bare
Red wire bare uncapped
black wire with sticker saying 115 volts secteur line bare wire uncapped
Yellow wire with a black wire coming from the fan transformer caped together
White wire bare and uncapped on fan transformer
black wire bare uncapped
green wire bare uncapped
Gas valve has brown wire going up to fan transformer
I hope this makes sense....Thanks Robert
Old 08-23-15, 09:35 PM
Unfortunately your descriptions of the wiring isn't going to be enough. Is it possible to take a few pictures and post them here ? http://www.doityourself.com/forum/el...rt-images.html
Old 08-24-15, 01:54 PM
P
Here are the pics of the wiring, hope you can make them out. The fan wires are 1 wht and 1 blk, I thought they we're brown.
Thanks again Robert
Size:  43.0 KB Name:  SAM_0044.jpg-2.jpg
Old 08-24-15, 04:47 PM
We're getting there.
I need to know what is connected to the transformer.... just to the right in the picture ?
I need to know the colors on the gas valve.
I see a black and white wire leaving the box on the right. That supplies the transformer.
I see two colors leaving the center ko and going to the fan. Is that brown and yellow ?
Where does the black, red and yellow wire go to on the left ?
