Mr. Heater firing problem
Old 02-15-17, 08:49 AM
Hello, new to this site. I have a Mr Heater HSU75 in my garage, has worked flawless for 4 years. Went out this morning and hit the tstat, Heater did what it usually did but wouldn't light. I did some looking and noticed the "Tick tick Tick" you hear is very faint. The heater is clean inside no cob webs or anything of the sort. I decided to grab a long handled lighter. I shut everything down and waited 10 minutes. Turned elec back on and fired her up. This time I took the long lighter and when I heard the faint tick I lit the lighter. Heater fires and works great. I did this 3-4 times. I think maybe a bad ignitor? Bit when I look for the ignitor I see two things that look like the ignitor. Are there two? Any help would be great Thanks in advance. I see no spark at either one, but not sure which is supposed to spark!
Old 02-15-17, 10:12 AM
Received 343 Votes on 321 Posts
Welcome to the forums.
That is a direct spark ignition.
You are probably seeing the spark probe and the flame sensor rod.
If the spark is sparking to the burner then it is working properly.
Look at the control board. The green LED should blink a trouble code.
Name:  mr heater codes.jpg
Old 02-15-17, 10:31 AM
I had two flashes, once i turned off the power I did it again now its just a nice steady flash, (after I light it with BBQ ignitor). There are two pieces in question one is at the top of the burner its a long circular white thing with a rod coming out of it. There is a white wire feeding it, the other at the bottom of the burner looks the same but there are two rods coming out of it, feed with a red wire. I'm not sure which is the ignitor. Tried googling it but no luck. I see no spark at either one, but not sure which is supposed to spark!
Old 02-15-17, 10:53 AM
On page 17 of the manual shows a parts breakdown of the burner assembly area.
Look at parts 3 and 6.
szmanuals/be1149d9f3f8972ccb3141c009659fc4.pdf
Old 02-15-17, 11:01 AM
Must be the bottom one, the one with the two leads (although it only shows one lead in that pic). Found another site guy had same problem as me, it was his circuit board. I have a call into Mr. Heater to talk to a tech guy. This blows, always something
Old 05-26-18, 02:58 PM
Mr heater flashes 3 times
Hi i am new and not sure how to start a thread to discuss my problem. My unit flashes three times thus indicating the pressure switch however if the blower does not start such as in my case I would expect the error to indicate this.. I have checked the lower motor and it works however will not turn on. I would appreciate any insite..
thank you
Roger
