Need help wiring Reznor XL-200-3
Old 11-13-19, 09:12 PM
Hi I am in need of desperate help wiring this reznor xl200-3 hanging garage natural gas furnace. The guy I bought it from disconnected the wiring on it. This unit has the fan,thermostat/gas valve, transfomer, and power in.I hope to get some information and /or a picture of the wiring thanks for the help in advance.
Old 11-13-19, 10:21 PM
Received 416 Votes on 389 Posts
Welcome to the forums.
Make sure the heat exchanger is not rusted thru before you spend any time or money on that old dinosaur. I believe that heater is over 30 years old. I have not found a wiring diagram for it. It should be very basic to wire. The link below is a parts list for it.
XL parts manual
We did help another member wire up his old ceiling hung unit similar to yours but it required pictures of all the control parts so that we could explain what to wire. How-to-insert-pictures.
Old 11-14-19, 05:42 AM
Geochurchi's Avatar
Received 19 Votes on 19 Posts
Hi, anyone of those I have wired was pretty much self contained, just brought a feed to a disconnect switch on the side of the unit, and possibly relocate a Tstat.
Geo
Old 11-15-19, 10:07 PM
Wiring...
I am new to this i haven't figured out how to attach a photo yet probly because all i have is a phone to work off of...i will explain this as good as possible... I have a red,yellow and a black coming from inside the unit..(i know where the yellow goes as it was cut off of a black one) than i have a black and white wire for the fan and a black and white wire to the transformer..from the transformer on the out side with the screws there is a brown wire going down to the gas valve and a lose blue wire...now on the gas valve there is that brown wire from the transformer and a black lose wire.....i hope this helps thanks for the help its very appreciated
Old 11-16-19, 04:43 PM
Your three wires coming in may be always hot, thermostat and neutral.
The problem is there is a limit switch as well as a fan thermostat in that heater.
If it doesn't have a pilot then it has an ignition box.
Many phones won't load pictures here properly. I always use my laptop.
Old 11-18-19, 09:22 PM
Wiring...
PJ MAX you can't tell me any thing with my description?
Last edited by PJmax; 11-20-19 at 09:59 PM. Reason: added member supplied pictures
Old 11-19-19, 07:07 PM
Check out the following link. See if this is like your unit. I think it covers all the XL series.
Reznor XL series manual (pdf)
