Convert LP Patio Heater to NAT
Old 09-06-20, 09:07 AM
Hi. Looking to convert a 48000 BTU patio heater to Natural Gas. I've removed the housing and LP hose/regulator. What's the next steps? Is there an orifice somewhere which needs to be replaced or made larger? Thank you.
Old 09-06-20, 09:56 AM
Received 1,021 Votes on 947 Posts
I added an arrow to your picture. That's an orifice assembly.
Was there some type of cap screw on there ?
It looks like the brass orifice assy is removable which mean it's replaceable.
What is the make and model of the heater ?
Old 09-06-20, 10:11 AM
https://www.lowes.com/pd/Garden-Trea...ter/1000664673
the only thing I removed was the hose which was connected to the flair fitting.
I thought there was some tiny orifice somewhere. Youíre pointing to the flair fitting, correct?
Old 09-06-20, 10:59 AM
Yes.... unfortunately I was pointing to the flare fitting.
Didn't realize at first the heater was upside down.
Anyway.... I changed the labeling. The orifice is going to be in the top section just under the burner.
I'm looking for a replacement natural gas orifice for that model.
Old 09-06-20, 11:07 AM
F
found it. Now the question is with what do I replace it with
Old 09-06-20, 11:24 AM
I removed the orifice. 5/64 drill bit fit all the way through. 3/32 did not. Should I just drill the orifice with the 3/32?
Old 09-06-20, 11:26 AM
Good question. I haven't found anyone that sells a replacement for that heater. It's basically designed for propane only so no one will offer a NG conversion orifice. There are two videos below that did what you want to do. They drilled out the brass orifice. It's going to require drilling a little bit at at time to find a proper flame. You'll also need to block off some air to the burner.
Patio heater conversion 1
Patio heater conversion 2
Old 09-06-20, 02:13 PM
So I drilled to 3/32 and hooked it up. Works but donít know how well yet since itís hot outside. Iíll check the flame when it gets dark. Thanks.
Old 09-06-20, 02:15 PM
If you watch those videos.... they show covering up some of the air inlets to the burner.
You may have to try that too.
Old 09-06-20, 02:42 PM
If you look at my original pic I donít see any air inlets like the video. 🤷🏻‍♂️
Old 09-06-20, 02:49 PM
Look at the picture where I put orifice. The entire area below that is an air vent.
It allows air in at that point to mix with the gas on the way to the burner.
Old 09-06-20, 04:41 PM
Here
s the result. Flames are blue and appears at the right height per the manual.i didnít block any airflow.
Old 09-06-20, 04:49 PM
Looks pretty good from here.
