Duo-Therm propane wall heater
Old 12-15-20, 08:28 PM
R
Question Duo-Therm propane wall heater
Yes i have a duo-therm heater maodel l569655 i think it was from 1985 or something anyways nthe ploit lights and stays on until the main burner tris to kick on which also blows out the ploit light to i just replaced the regulator any ideal on how to fix this im poor as hell so cheap fix is best willing and capable of trying any sugestions
Old 12-16-20, 12:36 AM
Received 2,965 Votes on 2,675 Posts
Welcome to the forums.
Duo-therm.... is this in a motor home / RV ?
That's not a model number I recognize. Please confirm.
You should have an intermittent ignition pilot.... not a standing pilot.
Make sure your propane tank valve and the valve on the furnace are both open.
Old 12-21-20, 10:56 AM
R
Duo-Therm
It for a travel trailer and I've checked the values on the propane tank replaced the tank regulator the tanks are new and Everything else in the trailer that use propane is working fine but when the burner comes on yes it blows out the pilot but the main burner doesn't light either I've cleaned it out and made sure it's got a good and tight seal as it says but it still won't work right could it be the three coupler or the regulator on the unit itself?
Old 12-21-20, 06:36 PM
I need to know the model number on that 35 year old heater.
